Dana 60 build and swap
Old 07-08-2013, 07:24 AM
  #71
dlincoln91's Avatar
Originally Posted by wildace
Mocked everything up with all the brackets tacked on to check fit and measurements and found I need to use different lower control arm mounts in the rear and I'm probly going to keep it radius arm in the front instead of triangulated uppers
Attachment 475848
would you snap some pictures of the axles and everything a little closer up
Old 07-08-2013, 08:34 AM
  #72
wildace's Avatar
Yeah but right now I have the front out and on saw horses so I can weld the truss and brackets on then rebuild it
Old 07-17-2013, 04:12 PM
  #73
wildace's Avatar
Ordered everything else for the build and put in for vacation next week so I can set up the gears and lockers, install the shock towers, make the upper front links and put everything back together for when the shocks show up
Old 07-25-2013, 09:17 PM
  #74
wildace's Avatar
Worked on the front axle for the past two days and tomorrow ill slide it under the jeep and start with the steering linkage and rear axle gears and locker after I finish plumbing the hydro assist.
Old 07-25-2013, 09:27 PM
  #75
wildace's Avatar
Old 07-26-2013, 05:40 PM
  #76
wildace's Avatar
Made a mount for my powersteering reservoir then plastidiped my grill and started mounting my bumpers today
Old 08-07-2013, 03:54 PM
  #77
wildace's Avatar
Shock towers showed up now its time to get the rear axle done so I can start on these
Old 08-08-2013, 04:57 PM
  #78
wildace's Avatar
Got my struts in today and wasn't expecting them
Old 08-15-2013, 02:55 PM
  #79
jvandy50's Avatar
Do you know of any other 4drs running the ORIs?
Old 08-15-2013, 03:04 PM
  #80
wildace's Avatar
Yeah there is a few guys on this forum and a few on the wrangler forum
Quick Reply: Dana 60 build and swap
