Dana 60 build and swap
Old 05-30-2013, 12:31 PM
  #51
wildace's Avatar
Old 05-31-2013, 12:12 PM
  #52
wildace's Avatar
Decided to change directions on the build and bought a 79 f350 axle so I have more space to mount brackets on the driver side and keep my strut mounts lower on the axle so that it isn't too tall. Also got the new truss on order today
Old 06-11-2013, 08:36 PM
  #53
wildace's Avatar
Got some parts in today and more coming tomorrow
Old 06-12-2013, 06:52 PM
  #54
wildace's Avatar
Wheels made it after being on backorder for a month, now I can start welding the beadlocks on
Old 06-12-2013, 10:17 PM
  #55
BKGM Jeepers's Avatar
Originally Posted by wildace
Its 69.25 wide so its really not much wider than the jk axle tha will also help with tire wear cause I won't have to use as much offset to get the same track width as I had before
Aren't stock JK axles 61" wide? TJs are 60 and my rear 60 was 61" for a stock bolt in but my front was 66" because of the coil buckets and C thickness. I run coil overs now which could have allowed me a couple less inches but I don't see a front 60 being less than 64" WMS to WMS.
Old 06-12-2013, 10:18 PM
  #56
Attachment 463353
How did you get you electronics to work with a self build? Does someone sell a kit?
Old 06-13-2013, 05:57 AM
  #57
Former Vendor
TOTL Innovations's Avatar
Stock JK axles are 65.25" from WMS to WMS.
Old 06-13-2013, 07:02 AM
  #58
wildace's Avatar
Thanks I didn't want to be the one to tell him he was wrong
Old 06-13-2013, 07:24 AM
  #59
wildace's Avatar
Also you have a custom 60 and I'm using pullouts from a one ton truck that's why my axles are approximately 70 inches wide
Old 06-13-2013, 07:26 AM
  #60
wildace's Avatar
Also bought a retrofit kit from dynatrac
Quick Reply: Dana 60 build and swap
