Dana 60 build and swap
#191
I'm not sure I'd do the 2nd gen front axle I'm pretty sure they were all low pinion until the 3rd gen
#192
awesome rig man
im about to do the kingpin d60 and 14bolt ff rear on my jku. also doing the ori struts with a comp cut and stretch
what all comes with the dynatrac retrofit kit, and what all is involved in doing it?
#194
i haven't really seen too many kits out there. what others are available?
not yet, not starting the next phase of my build till after march
what size struts did you go with?
#195
Ill have to get back to you on retrofit kit cause I have website saved on my computer at work and went with 14 inch struts cause I wanted to keep mine as low as possible without having to cut into the hood
Sent from my EVO using Tapatalk
#196
#197
im trying to keep mine as low as possible too....lol the 7.5" of lift i have now it too much id like to be somewhere around 3.5-4" of lift. will also be running 42x15 tsl's
#198
That won't leave much room for a longer shock unless you cut through the hood or run a shorter shock mine works out to roughly 7 inches of lift on 40s and I have just a few inches till the towers are to the hood
