Dana 60 build and swap
Old 12-11-2013, 06:39 PM
  #171
PartySnake's Avatar
Nice build man What back spacing are you running on those wheels? I've been thinking about doing an outboard setup for the rear but only have a stock axle but have a 3.5'' bs. I know i would deffinatly be frenching the frame, but with such a heavy offset I think the clearance would be similar to most fullwidth setups i have seen/read up on.
Old 12-11-2013, 06:44 PM
  #172
wildace's Avatar
I'm running 3.5 offset
Old 12-12-2013, 04:28 AM
  #173
kgw350's Avatar
Default Great info in this thread
I just read through all the pages great info. I have a 10.5" sterling im working on and a 2002 f-350 dana 60 front for my 2013 2dr.
I saw your vids from rausch creek I know that that spot in the second vid this is a vid in my old 4dr on the same spot. I think its the same spot?
http://youtu.be/ths7MpePzTg
Old 12-12-2013, 05:12 AM
  #174
wildace's Avatar
YouTube Link: http://youtu.be/ths7MpePzTg
Yeah I believe that's it and the trail is yellow jacket and its just before trail #5, just after I did yellow jacket I took mine up the rough side of the trail#5 hill climb but nobody was recording video
Old 12-13-2013, 10:55 AM
  #175
ABENDX's Avatar
Hey buddy... just an update since I said I would.
I'm just under 5100#. Fat for sure!
Old 12-13-2013, 11:21 AM
  #176
wildace's Avatar
Yeah a lot more than I would of figured you would be for a 2 door
Old 12-15-2013, 04:00 PM
  #177
cmb927's Avatar
How much were the set of ori struts? I'm torn between coilovers or these
Old 12-15-2013, 04:11 PM
  #178
wildace's Avatar
I got mine for 495 each
Old 12-15-2013, 04:29 PM
  #179
cmb927's Avatar
Have you any experience or knowledge of coil overs? I'll spend most of my miles on road
Old 12-15-2013, 04:55 PM
  #180
wildace's Avatar
I have some experience with coilovers but the biggest thing with being streetable is going to be your suspension design the ORIs are fairly new and I really could find much info on people running the on the street so I looked real hard at the specs and couldn't see why not so I built everything around them by pushing the mounts out as far as I could to help keep it stable without the use of swaybars. I've put almost 8000 miles on my setup and so far I'm super impressed with the ORIs I can speed around turns with less body roll than a old Chevy pickup and I feel certain that I wouldn't be able to do that with coilovers without swaybars on the street plus changing the hight and rates of the shocks are easy as filling a tire with air
Quick Reply: Dana 60 build and swap
