Dana 30 Leak
Old 03-21-2008, 12:39 PM
MBAR741028's Avatar
Default Dana 30 Leak
I have diff fluid leaking out of the front drivers side axle tube onto the steering knuckle. I just changed the fluid could this be from overfilling it? Or is the axle tube seal leaking and need to be replaced? Thanks
Old 03-21-2008, 01:50 PM
RedneckJeep's Avatar
What procedure did you follow when you refilled it?
Old 03-21-2008, 01:52 PM
MBAR741028's Avatar
procedure? Just dumped some fluid in up to the fill plug.
Old 03-21-2008, 03:40 PM
MBAR741028's Avatar
Does anyone know where the level should be with a solid diff cover.
Old 03-21-2008, 04:24 PM
VBS4's Avatar
I'll find the thread and post it for you, but you're supposed to put only the amount called for by the factory. If you fill more than that, you will have a mess on your hands.
Edit.......
Here you go:
http://project-jk.com/jeep-jk-write-...hange-write-up
Scroll down to #6 on the instructions.
Good luck
Old 03-21-2008, 04:44 PM
MBAR741028's Avatar
Question
Edit.......
Here you go:
Good luck
Thanks for that. I am going to drain it tommorow and fill with the amount that says. I still dont think any should be leaking out of the axle tube it seems from what i've been reading that if it were over filled it would leak out of the breather tube.
Old 03-21-2008, 04:49 PM
VBS4's Avatar
I agree with you but.....The gear oil will take the path of least resistance. So check the top of your breather and make sure it's not clogged while you're under there.
Old 03-21-2008, 04:52 PM
jeep08ham's Avatar
I would encourage you to check and make sure the vent line is not plugged at each oil change on the diff's. I have seen them plug up and force the oil out the axle shaft seals too.
MBAR741028's Avatar
Will do thanks
Old 03-21-2008, 05:34 PM
MBAR741028's Avatar
I just drained it and there was only about 1 quart left in it. It must be the axle seal. Shi*. I wonder what caused the failure.
Quick Reply: Dana 30 Leak
