Dana 30 and 5.13
Sure there is, they aren't installed yet.
BTW, I have an 11 with 37s, auto trans and 4.88. It's fine. Don't believe the idiots telling you "don't fear the gear"!
I see you're in Texas also. If you're in the DFW area I'll be more than glad to let you drive mine and see how you like it. Keep in mind, mine is a JKU so it weighs a bit more than yours as well. Also, FWIW, my 08 with the auto I did as all the self proclaimed experts said and had 5.13s installed. Should have gone with the 4.88s. That's why I did with this build.
Sure there is, they aren't installed yet. BTW, I have an 11 with 37s, auto trans and 4.88. It's fine. Don't believe the idiots telling you "don't fear the gear"! I see you're in Texas also. If you're in the DFW area I'll be more than glad to let you drive mine and see how you like it. Keep in mind, mine is a JKU so it weighs a bit more than yours as well. Also, FWIW, my 08 with the auto I did as all the self proclaimed experts said and had 5.13s installed. Should have gone with the 4.88s. That's why I did with this build.
Dang maybe I should have gone with the 4.88. I wish I wash in the DFW area but I'm about 2 hours away
Most truss kits don't support/bridge the center section so it will flex without the strength of the heavier diff cover.. Actually I don't know if there is any truss kit available for the D30 that bridges the center section..
5.13's in a D30 with a 3.6?? Well if you don't wheel much....
What's the true size of those 37's?
** Just saw that you've got a 3.8. Never mind.....
