D30... Too Build or not too build
#22
The problem with this chart is that not everyone wheels their Jeep that hard with monster tires, but they'd like some improvement over what the stock D30 offers. There are cheaper alternatives to the ARB locker, the ball joints, the RCV axles, and so on, and some parts aren't needed (such as the truss). I have about half that nearly five grand in my D30, and wheel reasonably hard for expedition/overland travel. Harder than what I'd want to run a stock D30, but certainly not as hard as a few on this forum.
I'm not saying the chart is wrong. I'm saying that it's not right for everyone. People should be honest about what they intend to do with their Jeep, then plan and budget accordingly. And I would encourage the vendors who are eager to sell their wares to ask the right questions and offer suitable advice for each individual's situation and needs.
126K miles and still going strong on a built D30 (hope that doesn't jinx me, LOL).
My goal with my build is 37" to 40" tires and be able to wheel reasonably hard without fears of breaking down.
BTW thanks for sharing your pictures they are great! Your advice on Canyonlands got us the spend 2 days running the 91 miles of White Rim... Epic.
#24
If you are paying labor, you're right back to the same situation as the original chart --> with the added expense of that shiny new (used) rubi axle on top. There is no strength benefit to the rubi housing over the d30 housing. Same tube diameter, same tube thickness, same C's, so you still need the same gussets/sleeves/truss/hd mounts/skids/etc that you decided you need for the d30 housing. You get a much better R&P size, the e-locker, and slightly upgraded shafts, but odds are you're paying for new gears and the install. And if you are paying for a new 44 for the strength advantages, aren't you also going to be looking into alloy shafts and serviceable balljoints as well?
So yes, take-off rubi axles 'can' make sense. Depending on your skills and needs. Add up all of the costs and do a 3-way comparison between building the d30, buying a rubi 44 and then building it, and just going aftermarket to see what is right for you...
#25
If you can do the work yourself, and find them for a decent price, it can make a lot of sense. (or if you can find one that is already upgraded for a decent price, it can be a great purchase!)
I have an awesome 4x4 shop nearby and he's been doing it for just about thirty years now
For me the new complete package just makes more sense than doing all that work to my factory 30
Matthew
Sent from my iPad using JK-Forum
#26
I'm not a welder or hard core mechanic, I know what I can do myself and what I can learn to do with the right tools and instructions and for the other stuff I find someone who is competent and easy to work with at a fair price...
Matthew
Matthew
If money is not a consideration, why not get the PR 60 and be done?
#27
I'm pretty happy with the specs and options with the 44 that Northridge has put together
I think that will be perfect for my front, then I'll weigh the options for the rear
Best way to have money is to spend it wisely and to remember what it was like before you had spare money for things like this
#28
Another thing to consider, ground clearance with a ProRock OVER a standard housing.
#29
can a pro rock 44 fit a FULL size 35 spline axle shaft? imo if your building one up build up a 60 (for the front) seen as you can get them for $120 at most junkyards.
#30
The Northridge is looking awfully good to me, just wish they made the same special setup for the rear too!
Then I could drive my Jeep all the way to them and get the switchover done by Northridge
Matthew
