D30??
#21
Axle and stub shaft, you broke the ears on the stub shaft at the joint and also internally on the axle shaft itself? Hell, I'll stick with stockers then, I got extras. Chromo overated. Same thing kinda happened in my cj rear , spun the splines on a hub, went ahead and put a chromo in with a new hub and snapped it within a week Put the stocker back in and just went through hubs after that.
I rather have the shafts as the weakpoint. I rather change a bunch of shafts than have the shafts be stronger, and grenade the R&P. Careful with those RCV's. If you get a D44 to run these shafts, you'll now have strong shafts, and the R&P is the weakpoint.
#22
Yeah, I'm debating on those right now. Depends on what I break in the d-30 as to which direction I'm going, I've got some spare stockers, and a lockright in the front. If I screw the R&P or carrier, I'm goin d-60, if it's just axles , may go rcv. We don't have allotta rocks here, just muddy trails, so.... I actually hammered them pretty good yesterday on a trail, so far, so good, not rocks though, think that's where I'd run into probs.
