Cylinder Head compatability
#21
just out of curiosity frank, what were the cars that you were putting cams into? I have installed cams in a wide variety of vehicles from 4 cylinders to v8's fuel injected and carb'd and have seen significant gains in the low end, mid range and top end....all depending on the motor they were installed into as well as the specific grind of the cam.
#22
#23
My 350z for one. A honda civic hatchback. Buick grand national, 06 mustang. All were turbo'd. And from dyno results the gains were up high. And kept the TQ curve good and flat. Where with out the cams the wtq would fall off. I'm no BS er. If you new me personaly you would know that. In my lastest project which was the Z. I installed bc2 cams. Which allowed me to take my rev limit up to almost 8600 rpms on a built block of course with a compression ratio of 8.8.1 I had the fastest z in my area besides my buddy Hal at injected Performance in lexington. his street car was putting out 900 whp on Q16 running a custom single GT47r. I also ran water/meth in all of my cars. I have never built any V8's all 4 and 6 cyl only. The grand national was my first car which had a factory turbo and got me hooked on boost It was cam'd also. And I ran pure meth in it. Till the fuel system got all ate up. Then I learned my lesson about pure meth. And that was a little over 15 years ago.
As far as the higher reving small displacement motors go, I have worked on SRT-4 motors, as well as N/A 2.0 and 2.4 chrysler motors. the 2.0 chrysler motor was higher revving than the 2.4 due to differences in the stroke and the 2.0 saw gains more in the upper hp range while the 2.4 saw incredible hp and torque gains after being cammed. The N/A 2.4 I swapped into a lightened neon 2 door, had custom grind crane cams in it, high comp pistons, head was ported/polished, custom box intake with 70mm tb, custom tri-y long tube header with 1 7/8" primaries into a 3" merge collector. That engine started life around 150 hp and was putting down close to 300 with no power adders like nitrous or turbo. I also have done cam work on honda engines where the only gains to be had were in the high rpm range (since honda motors make absolutely no bottom end power!)
#24
#25
Gridded, and looking into changing the timing, if possible I'll like to get rid of the timing chain and do gears. I have a pile of Krap to have someone in Chrysler sit on it..
