CV Joint to Double-Cardan Joint?
It looks like the seal on the CV joint on my driveshaft is finally starting to go on my 2010 JKU, with 2.5" lift & 35s.
Way back when I had my 95 ZJ, I had the CV joint replaced with a double-cardan joint on the original driveshaft. What options have some of the members here done?
Thanks
Thanks
Teraflex has a high angle CV joint you could replace with, but for that price I think you're better off just getting an aftermarket shaft. The u-joint in that factory shaft is not replaceable, without some real craftiness, so it's better to just get something that is better longer term. my 2c at least.
https://www.amazon.com/TeraFlex-1744.../dp/B01EXLIZDA
russianwarshipgo (07-01-2022)
DC shaft good quality will start around $600. And you religously have to grease the zerk fitting in the DC unit housing every 5-6000 miles. Recommend the one where you change the yoke at the TC end. Front end plate is a stock replacement. No issues there.
Thanks for all the help
It's been a while since I recall seeing someone replace with that TF CV. That isn't to say nobody has, just nobody posting about it (posts in general have really dried up over the years). I'd be curious to hear any follow-ups if you ever have an issue with it. It seems everyone I recall from the past that installed that was pretty happy with it. Hopefully it's trouble-free for years to come.
