Cut pinch seams
Old 06-24-2013, 03:42 PM
bgray's Avatar
The cut was simple. Had to to clear my 37's. Cut the rock rails and pinch seams without removing. Easy as can be!
Old 06-24-2013, 04:53 PM
Ncb
Ncb's Avatar
I used a miter saw with a metal blade to cut the sliders. Drilled a new hole and installed the end cap.
Old 06-24-2013, 05:18 PM
engineeredjku's Avatar
Yeah the cut would have been easy for me too. I started to make it with a cutoff wheel but couldn't get around my tire. Went to take it off and the #%*$ locking lugnut wouldn't come off!! That's how I ended up at the dealer(only 4 miles away) and they ended up cutting for free after taking all the locking lugs off. Don't know if anyone else has run in to that with the lugs. When I had my wheels/tires installed they had to cut off the end of the locking key since it wouldn't fit around the lugnut. With that setup it is near impossible to get any torque on those lugs!! If that made any sense whatsoever. Pretty much just means splines are on order
Old 06-24-2013, 08:57 PM
jeepwave's Avatar
I cut mine in 5 minutes with a wheel on the dremel
Quick Reply: Cut pinch seams
