Cut or No Cut Brackets with Long Arm Lift?
Ok, I'm trying to decide which 6" long arm lift to buy. I thought I was set on the Teraflex LCG lift, then I went to the Jeep Fest in Denver and saw a 6" Pro Comp Lift that did not require you to cut off the stock brackets or to weld the new long arm brackets in place. What are your thoughts on this?
I like the idea of being able to keep my stock Rubicon suspension to put back on the jeep should I ever decide to sell the jeep (for example to upgrade in 10 years when better technology.... electric jeep?... comes out). I realize not welding the brackets in place will not be as strong, but it must work....
Are there any other lifts that don't require cutting off the stock brackets out there that people recommend? I have heard the full traction lift is just too squeaky and that drives me nuts.
Sponsoring Manufacturer
Somethings to keep in mind: How heavy is a 4dr JK? Your factory brackets were welded on for a reason. Sometimes a bolt on kit can take as much time as a weld on kit to install. TeraFlex LA kits are a weld on kit for strength and piece of mind. Also take a look at what comes with a TeraFlex 6" kit vs. Pro Comp's. The 4" kit has everything the 6" doe's but the #1600440 flip kit and 6" coils/shocks. Take a close look at TeraFlex control arms/bracket/ trackbars and compare them to ProComps. TeraFlex has been running Clevite style bushings on these kits from the start. Makes for a nice quiet ride along with the rebuildable flex joints on the other end. Take a look at this "Control Arm Comparison" on our website. http://www.teraflex.biz/tech/control-arm-comparison-2/
cutting brackets
I have no doubt the Teraflex lift is the better lift with all the parts you need. I'm just worried about having regrets later if I wanted to put the stock suspension back on to sell it. Who knows, gas could get up to $10 a gallon and selling a jeep with a 6" lift could be impossible.
Good Luck. Iam sure as well you could even oderthe stock mounts
well if you are going LA I assume you are gonna wheel the piss out of it... so the Jeep will be beat up anyway.... if not go SA or hold out for th eEVO LA kit
Former Vendor
Once you go long arm, you will never go back. We agree with Tera that welding in the mounts is simply the best structural solution for your JK when you drastically alter the suspension; i.e. going long arm!
Rock Krawler Suspension
The most innovative JK Suspension Available!
