Custom rock rails redone
Old 01-29-2009, 10:23 AM
  #21
Crazyboattower's Avatar
Originally Posted by 2climbbig
Sorry, did not see the body mounts. That will help considerably and was one of my earlier points. That should work for you. Also I see you only have two mounting to your body mounts and not three as I stated. Hey, I had a few beers. This is basically the same design as the rubicon rails and should serve you well.
It's cool, no big deal . I just felt the need to reexplain what I did and why.
The mounting system I used has not changed since I made them the first time. I should have used the 3rd body mount and will more than likely do that when I get my lift and new tires, but for now they are going to stay. I really need to find some longer body mount bolts before long, but it works for now.
Old 01-29-2009, 10:25 AM
  #22
Originally Posted by Dante
Add some tread tape and you're all set.
I would use some grip tape but I sprayed it with bed liner, which has some texture to it, and I don't usually stand on it, but great idea.
Quick Reply: Custom rock rails redone
