Custom rock rails redone
#21
Sorry, did not see the body mounts. That will help considerably and was one of my earlier points. That should work for you. Also I see you only have two mounting to your body mounts and not three as I stated. Hey, I had a few beers. This is basically the same design as the rubicon rails and should serve you well.
The mounting system I used has not changed since I made them the first time. I should have used the 3rd body mount and will more than likely do that when I get my lift and new tires, but for now they are going to stay. I really need to find some longer body mount bolts before long, but it works for now.
#22
