Custom Alignment specs
Correct. The problem those of us with 4wd have is the front driveshaft. (the trade-off between caster and pinion to keep both angles good). With no front driveshaft, high caster should not be an issue. It will make the steering feel heavier, maybe affect the return-to-center, not sure if tire wear can be affected?
