Custom Alignment specs
Hey JKF
I think I finally got rid of my DW by using some caster bolts...I was only able to push about 4.9 on driver and 5.0 on passenger...I want to add the adjustable arms and push it more to about 6.5-8 deg of caster...does anyone have any input on this...is that too much caster? Thanks Alec
Going from stock 4.2 caster to 4.9 cured your deathwobble?
6.5 degrees is probably too much caster for a stock housing, 8 degrees is definitely too much. As the caster increases, the pinion points further down, the driveshaft joints run at steeper angles, and you get vibes. Vibes that will probably destroy the joints, or in several previous threads, took out the transfer case. If you want to run that much caster, look at cutting/turning, a $1450 Spyntec kit, or one of the $2000 aftermarket 44 housings
Also, if you are adding adjustable arms, you will probably want to remove the cams and either weld up those holes or buy a 'cam eliminator' kit (think it's just thick washers...)
6.5 - 8 degrees is too much caster for a stock housing. As the caster increases, the pinion points further down, the driveshaft joints run at steeper angles, and you get vibes. Vibes that will probably destroy the joints, or in several previous threads, took out the transfer case. If you want to run that much caster, look at cutting/turning, a $1450 Spyntec kit, or one of the $2000 aftermarket 44 housings
5 degrees seems to be a good compromise between caster and pinion angles. Just depends. You will find a few people running higher, but not all that many. (I am running at 7 degrees, but I have a caster corrected housing...) Try it and see what you think. My guess is that you will feel the vibes and back it down. Or just second guess it, get scared of blowing the tcase, and back it down.
Are you talking about lengthening all four arms to extend the wheelbase? Or just tiling the housing for caster/pinion?
For caster/pinion, extending both lower arms will lower the pinion and raise the caster. And shortening both upper arms will do the same thing. (or do it backwards to raise the pinion and lower the caster) Which you go with just depends on the current axle centering.
If it is centered forward/backward in the wheel well, and the bumpstop pads are aligned, most people will say to adjust the uppers to set the caster/pinion. (but, adding or removing a single degree of caster will make a negligible difference in wheelbase/centering, so I don't think it really matter which you choose)
yea extending the wheelbase...
How much lift ?
As mentioned 5-6° is pushing the limit of your driveshaft angle if lifted. Stock .. You should be ok.
Extending both adjust wheelbase. Uppers/lowers only caster/pinion.
Lowers have more affect on pinion/caster because of mount location closer to the axle tube.
How much lift ?
Hey JKF
I'm no rocket scientist but I still say 6 deg is way too much and you'll start having drive line issues if that's where set it. Good luck!
