Currie Rock Jock Anti Rock
So I just installed the Currie rebranded Rock Jock Anti Rock on my JK that only has a 2 1/2” TeraFlex lift. The rod ends are totally bottomed out on the links, I was trying to get the arms as parallel to the frame as possible and this is best I could do. Is this what others have done on a 2 1/2 lift? I was a little pissed that right control arm sticker was scuffed up but that’s what it is.
For an off road rig you want the arms adjusted so that they don't cause any restriction at full droop. Most advise adjusting them a bit high so they don't act like limit straps. You should be good to go.
