Currie rear 60 vs Dynatrac Rear 60
#31
Yes, high pinion on both axles. The TJ had a 5" lift, and the JK has a 3" lift. The high pinion raises the pinion yoke about 3" I believe. So I have a 2 door JK that is lifted and running 37s, with a stock rear driveline angle. Combine that with locking hubs on a front Dana 60, so that the rear driveline angle is stock, and the front driveline is not turning on the highway, and you have a lifted Jeep that drives smoother, and with less vibration, than it did when it was stock.
#32
The pinion angle is decided by control arms...yes it may be a tad higher on a hp but now you have a d60 that r&p wise isnt as strong as it could be.. Im no engineer and cant speak on how much weaker though. Plenty of people have done hp rears, but i personally wouldnt. Unless driving in reverse where it will actually mesh together..your ring gear teeth will want to push away. Its like pulling someone out in reverse. Most cases its advised not. You are now the exception..
#33
.......Correct me if I am wrong, but aren't full float axles primarily designed for pickup trucks that carry a lot of weight? The additional bearing at the axle end helps support more weight. But does it do anything to prevent torsional breakage of the axle shafts? For a light weight vehicle like a Jeep (4960 lbs total, and 2400 lbs on the rear axle for my JK) I didn't think a full float axle was an absolute necessity..........Then people can really tell you that you don't need that for 37" tires.
#34
I'll also advise to NOT run a high pinion axle in the rear. I have personally blown up 2 HP 60 ring gears (in a dynatrac axle) and I have replaced 2 others. I will NEVER run a HP axle in the rear.
Why not just have a shop build you a nice 14 bolt?
or I'm in agreement with the others.
weld a truss on that 44, run warranteed shafts and hammer it. stay away from 5:38 gears as they don't have a a lot of tooth contact and are weaker than any other ratio.
