Currie AntiRock
Currie AntiRock
Looking into getting Currie AntiRock sways. Questions:
1) what's the preferred brackets aluminum or steel?? And why?
2) are they worth the $$$$?
I went with the steel ... I wanted the aluminum but my shop said go with the steel so I did I think it was a bit cheaper..... For me not having to connect and disconnect all the time was worth the price
Former Vendor
Can't really go wrong either way. I went with aluminum front and rear so i didn't have to worry about rust (New England) and I love the contrast since my Jeep is all black. They work amazing-
Feel free to contact us any time for forum member pricing!
The aluminum versus steel is personal preference. The on road differences give the Jeep more body roll on road, but a more stable feeling offroad. I believe they are supposed to work best when paired front and rear, but at that cost one would almost consider going with the Teraflex adjustable sway bar that you can turn the dial for street or off road use.
As for on road stability, this is my daily driver. It does take some getting used to but I've had it like this for 2 years and I never even think about it anymore.
Me personally, I would not recommend these setups. The rear swaybar on the JKs are pretty small from the factory. I don't think you will notice much of a difference, if any, in the rear of a JK going from stock to Currie. For the front, just disconnect when you go offroad. It takes all of 2 minutes to disconnect and maybe 5 minutes tops to reconnect; even less with a Rubi. On the road you will have much more body roll with Currie swaybars, and for me that is not good. If you don't mind the body roll, then go for it and you won't have to get out of your Jeep and get dirty
