Crush Sleeve Help
Crush Sleeve Help
I did the 30 last weekend with no porblems. I am going back together with the rear fand cant seem to get the crush sleeve crushed. Any suggestions. I have a friend with a torque multiplier tomorrow.
When I did mine I made a tool out of a piece of flat stock, welded two studs ( bolts) to go through the yoke and drilled a hole in the center of it between the studs large enough to put a 3/4 inch extension through it. I just used that to hold the yoke by putting it against the frame and used a 3/4 inch rachet extension and short socket to tighten it down. Worked perfect and was just stuff I had laying around. Otherwise buy a large pinned spanner wrench to hold it.
