Cromolly front axles can break.
As to breaking the axles I recently did the math after talking to some axle venders at EJS. A generic D44 axle will take 7000 ft/# of torque before it may break. The newer D44's in our JK's with 32 splines may take even more. The math is 190 ft/# torque (at 2500 rpm) X 2.84 (ratio of auto 1st gear) X 4 (4:1 Rubi TC) X 5.13 (final drive ratio) = 11,702 ft/# of torque when the axle went. It was all going to that one axle as the wheel and tire where jammed in a crevice and nothing was turning. I'm actually kind of impressed by that.
One thing to note is that the 5.13 gears, as to which there have been questions as to strength, held up. I guess I'd rather loose an axle than gears as it's an easier repair.
It was that thick, super gooy, never let you go mud in the first two pics.
The trailer was about 1/2 full of beach clean stuff weighing about 2000 lbs.
It was in reverse while Rhonda was trying to pull me out.
Thanks lots dave, Guess i am comming over to pick it up?
They are Alloy usa's baught from Dave @ Northridge4x4
I would have to agree with Chuck45, i am glad the stub shaft is the weak link, i did check the rest and the other 3 wheels have drive with the lockers on and RubyDoo is a 6 speed and being she was in reverse at about 2000 rpm when it happened 190 ft/lb x 4.06 reverese gear x 4 x 5.13= 15829.????
I would recommend that you pull all of your shafts and check out your differentials. I was on the trail with someone not too long ago in a TJ. His shaft broke when he was turning to line up with everyone on the trailhead. Granted the shaft was only a Dana 35 shaft, but it clearly had old damage in addition to the spot where it broke.
For what its worth... that axle broke in perfect Shear. You couldn't ask for a better text book example of a break due to shear.
Nice and clean cross section.
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
My Alloy USA front shaft broke so clean it looked like someone put it in a lath and used a parting tool on it. My Superior rear shaft was not as clean and the middle 30-40% had a mountain peak on one side/valley thing on the other side going on. I was told at EJS that this was the prefered break as it indicated a more gradual give as opposed to a snap. I would like to hear other opinions on this as I don't know.
David at Northridge says he has some ARB lockers for the Rubi axle coming in in around 90 days. This will require new axles as the shafts will go from 32 to 35 spline. This may be a good thing as it should give us stronger axle shafts.
On the other hand I may just go to a D60 and have a D44 rear axles for sale with factory locker, 5.13's and Superior axles (to help defray the cost of the D60).
That is correct; no questions asked. Had they been stock I'd have been buying new axles.
