Critique my lift kit plan?
Old 08-19-2016 | 10:50 PM
  #21
Ajkaz's Avatar
Originally Posted by jadmt
I think rk has some pretty long free length. I have run 28.5 long shocks and coils don't unseat. I run 2.5" up front and 3.5" in back. I did have a set of rear coils sag but rk replaced them. I'm running pretty heavy and with this combo have an actual 3" front and rear. Lots of loaded off road trips including several moab trips,rubicon trail trip and leaving tomorrow for the granddaddy of them all the dusy ershim.
I was unseating them front and rear, it's the primary reason I switched to MC coils I have over 2" more free length at the same 3.5" lift height. Have fun on Dusy, we're going weekend after next!
Old 08-20-2016 | 05:32 AM
  #22
kjeeper10's Avatar
Vet Army
RK is on their 3rd gen coil
Progressive / linear
Triple rate short
redesigned triple rate with longer free length.
Running 11.2 travel shocks my front coil just becomes loose at full extension. No way would it fall out.
Old 08-20-2016 | 06:57 AM
  #23
tjkamp's Avatar
I currently have TF 2.5in cools on a 2door. Have full width front bumper with steel cable winch.
Got about 1.5in lift over stock in the front. I have no rear bumper, no back seat. I am running a hard top and a full size spare that is about 25lbs heavier than stock Rubi spare. I got 1in lift in the rear.
Jeep has always had a little passenger side lean. A first the TF coils were about 1/4 in lower on the passenger side, similar to stock, now it is much more pronounced, I'm guessing 1/2 - 3/4 of an in lower on the passenger side.
I will be swapping out for RK 2.5in coils as soon as possible.
Happy Jeeping!
Old 08-20-2016 | 05:11 PM
  #24
Dbmoorejr's Avatar
Originally Posted by fido58
Thanks for the response! I'm currently running 33's and will stay on 33's until I need new tires, at which point I may go up to 35's. I did a lot of searching across various forums for a couple of weeks, and out of all my research TF was the one that seemed to be the most universally accepted as a high quality lift kit that didn't have any major issues. I was initially looking at Rancho because that is what my local Jeep shop (Jeepers Den) recommended, but between the two, people seemed to have issues with rancho over time. TF also fits within my budget. Are you not a fan of TF? I also wanted to go as high as I could clearance wise (I like the look), without having to immediately buy new driveshafts or all 8 control arms.
I went mopar stage 3, which is teraflex. Swapped springs last month for a better ride. Sold springs and broke even. Check into JKS
Sent using smoke signals
Old 08-20-2016 | 11:21 PM
  #25
Ajkaz's Avatar
Triple rate short
Your right, my RK were second gen, however my MC are fist gen and they got it right the first time...
Old 08-21-2016 | 06:10 AM
  #26
kjeeper10's Avatar
Vet Army
Just like they did with their tie rod haha messing with you.
Old 08-21-2016 | 08:00 AM
  #27
Ajkaz's Avatar
ExactLy lol
Quick Reply: Critique my lift kit plan?
