crazy noise help
crazy noise help
Just got in from driving jeep and the drivers rear tire is making a nasty clunking noise when i let off the accelerator, not touching breaks, just letting off. It still makes the noise when breaking???? but not when i accelerate. any ideas?
. EDIT was wheel lugs and I havnt removed wheels in like 3 weeks
Does this under deceleration straight, turning,
I walked along side of jeep while wife drove sounds like coming from in the wheel dont think its ice, started half way home on wet roads
Its not very common, but here is what I found working for Goodyear one day.
A woman ran over a small piece of piping/metal. It went in to the tire, but the tire leak was so slow that even a dunk test barely showed anything. After taking the tire off, we found the culprit. it rolled against the tire under centrifugal force. Once the wheel slowed so did the force and the object rolled around between the tire and rim like a quarter in a dryer.
Tampering with a motor vehicle is a crime. Call McGruff if you find a culprit
haha they were torqued. just cant believe only the one tire. Normally i would feel vibration wile turning if some were loose went thru that before
That is weird. Good thing it didn't come off completely for your safety. Also remember to try lock-tight solutions. A little on each stud can ensure you don't have a mishap like that again. Inexpensive product to prevent an expensive disaster
Was just saying that. i have red and blue sitting in the garage. might put a dab of blue on them.
