Crager V-5 15x10 wheels
Originally Posted by planman
Find another tire shop. Most 12.5" wide tires are rated for 8.5" or wider wheels. An 8" wide wheel is not so far out of range that there would be a problem. This is especially true with a taller tire. I can understand if you were running a 31" tall tire with 20" wheels that being 0.5" narrower than spec on the wheel might cause the tire to wear unevenly. However, 0.5" on a 35" tire with a 15" wheel won't matter.
Speak with the manager of the shop, not the desk clerk.
Besides, you want a narrower wheel for offroading when you air down to 10-12 psi.
Anyway I just found an off road shop I didn't knew existed before a few towns away so I'm gonna give them a call and see what deal they can give me. Hopefully I'll finally get to post some pics after getting the lift and tires done.
Reworked everything this morning for verification on measurements. They are pretty close, but it seems more on the 400 side. This is also to the bearing load, not the wheel studs. Trying to figure out the studs would be a little bit extreme for stuff around my house.
