Cragar Soft 8s 15" or 16" - Advice
Old 03-27-2010, 07:12 PM
nthinuf's Avatar
Originally Posted by iawalker
Anyone have any experience with 16x7s? The 16x8 Cragars have 5" of BS whereas the 16x7s have 4 or so inches and from what I've read 5" is too much.
Check the MFG's 'recommended rim width' specs for the tires you want. Many shops will not mount wide tires on narrow rims...
Old 03-27-2010, 07:27 PM
Stuka's Avatar
Go with 16's so your tires don't stick a mile outside the fenders.
I went with ProComps so that I could have the 4.5" BS.
Old 03-27-2010, 08:22 PM
iawalker's Avatar
If I went with a 16x8 would the 5" of backspacing give me any problems? I'm looking at getting tires in the 285/70-16 range which, if I'm not mistaken, would make the tire roughly 11.5" wide.
Old 03-27-2010, 09:06 PM
SoccerMan1080's Avatar
stick with the 16".... less hassle and more options
Old 03-27-2010, 09:28 PM
RN M OVR's Avatar
You will be fine. I would not go beyond 295/75R16 (33x11.5) with 16x8 with 5" backspacing. Yes, you can run that setup and be okay.
Old 03-28-2010, 05:31 AM
Grimscale's Avatar
I've been using the 16x7 Soft 8s with no problems at all. Even aired down, I've never popped a bead.
I'm currently running 285/75 R16s.
Quick Reply: Cragar Soft 8s 15" or 16" - Advice
