Cracked Teraflex Rear Axle Bump Stop
Old 11-21-2009 | 11:53 AM
aldaman's Avatar
Originally Posted by nthinuf
Glad you mentioned that. Install docs didn't say which direction they went, so I should probably go turn mine around...
....Not sure if they mentioned that in the TF instructions, but it does mention it in the project jk write-up....
Originally Posted by Project JK-2.5" BB
39. Place the TeraFlex rear bump stop extension on top of the axle bump stop plate making sure that the bolts go through the existing holes. On newer kits, this bump stop will be shaped like a parallagram and have a top that is skewed over to one side from the bottom. Install these with the top surface pointing towards the front of your Jeep JK Wrangler.
