Could OME shock mounts be hitting frame?
I have been searching for the cause of a noise upon hitting deep potholes. When I look at where the top of the shock mount is I think I see some small contact points above it on the frame above one of the threads. There isn't muchg clearance there. Is that possible? Anyone with the OME kit see this?
I haven't noticed this at all... no contact marks on mine. However, I try and avoid hitting any potholes. It is tight, maybe try and get a picture, and maybe we can figure it out.
The more I look at it, it seems unlikely that the mount could flex that much. At full flex from the side the distance doesn't change.
Someone A couple of weeks ago was having a similar problem I tried to find it for you but I couldn't, I remember something about the Bumpstops... they had OME shocks as well...
