Corner Armor Without Fuel Hole
Does anyone know if anyone makes a rear 2 door corner armor that does NOT have the hole on the driver side for the fuel filler? Id hate to have to cut out circle chunk of metal weld it in then grind it flush to eliminate it. Id prefer the corner also goes from the rear and cover the whole rear quarter panel. I cant seem to find any.
River Raider builder corners. He'll make them however you want them. The fit is on par with PSC.
Have you seen C4LO's (I think that's hIs username) comp cut and stretch build thread? He used them. Solid build thread as well. Don't recall which forum it's on. Just looked at it yesterday again. I think I googled Jeep JK comp cut. Let me know if you can't find it and I'll pull it up.
Yeah ive seen them, i knew they were custom. Ill have to see the price difference. Itd be easy to fill in. Im also debating just getting steel sheet and making them somewhat squared in the rear.
