cooper stt
Old 10-22-2008 | 04:21 AM
jtwjk's Avatar
Default cooper stt
i have stt in 265/75/16 it seems like i can feel evey lug while going down the road if im going under 40. it seems like i can feel the lugs digging in the pavement. any one else have this or am crazy. and i have the tire pressure at 26 chalk test and 26 seems best
Old 10-22-2008 | 04:23 AM
HappyCurmudgeon's Avatar
Eternal ***erator
I can feel mine up to about 5mph or so, after that not that I notice.
i have 33 x 12.5-17's and they seem to like about 28-29 street pressure.
Old 10-22-2008 | 05:12 AM
jayrav's Avatar
Your tire pressure seems kind of low for that size tire. I know you did the chalk test, but I think you better try again. I have the STTs, but they are 35" and I run them around 28PSI. I must admit that I haven't done the chalk test, but the recommended tire pressure for a 35" tire is 26-28PSI. As for your size tire it should be around 30-32PSI easy.
If you are running too low your hot air pressure will be too high vs cold air pressure. Remember there should only be a difference of about 10% between hot and cold air pressures. If hot air pressure is beyond that then you are probably under inflated.
If you really want to dail in your tire pressure you can weight your JK front and rear seperately. Your are going to have to divide the weight for each tire so you'll know how much weight each tire is holding.Then take a gander at your tire manufacturer's load vs inflation charts. This is still not an exact science since the weight distribution isn't symetrical. In that case measure the foot print and add air to the low side(bigger foot print) until they are the same.
I will admit that I haven't weighed my JK because I have yet to find a place where I could nearby where I live. So I took the lazy route...26-28PSI for 35" tires. I plan to try the chalk test and heat test soon.
I hope this helps
Good luck
Old 10-22-2008 | 05:27 PM
mkjeep's Avatar
I have 35x12.50x17, I only feel the lugs when I roll a couple mph, after that no roughness.
Quick Reply: cooper stt
