Convince me to get a locker
Old 01-14-2013, 11:54 AM
  #21
sneck's Avatar
Originally Posted by Bonedoc
It handles fine on the highway, no problems with shifting. I've heard people talk about erratic handling in rain or snow but truthfully I haven't noticed anything other than in really slick snow ice if you turn to fast and front tires loose traction it will want to push straight. That only seemed to be an issue if going faster than I should of been...lol. The other thing I did was make sure the rear tires have the same pressure in them, because it will pull to one side or the other on hard acceleration if the pressure is really off from side to side.
I don't regret it, it is noisy sometimes and it will unlock sometimes at the most awkward of times and it feels almost like something snapped. I've found that you get used to it and it becomes just one of those things you do when you drive your jeep. The offroad traction is nice though...
nice good to hear. for city driving I could care less, but my concern was on the highway, I had heard folks talk about older style auto lockers would cause some ..... scary behavior, but I think that was tied more to wheelbase then anything. so youve got me sold! thanks!
Old 01-14-2013, 11:57 AM
  #22
4W-Jive's Avatar
Far from extreme but my passenger rear tire is in the air (not the first or only time this day). You would not have been able to do this with open diffs.
  #23
suicideking's Avatar
Originally Posted by mpkelley20
One of the biggest things I've noticed about lockers vs non-lockers is that lockers "appear" to make wheeling safer in most conditions (not always but most of the time). Lockers allow you to stay on your intended line more often than not and let's you crawl over things where others need to "bounce" over them. Gunning it and boucning over an obstacle can lead to more breakage and possible other bad things if you happen to slide off your intended line.
Agree with this. It is safer and you're less likely to do damage.
Without the locker, you're going to have to try to get a running start and use the gas pedal more. This will make you break things vs. crawling over it locked at 1 mph.
Old 01-14-2013, 12:29 PM
  #24
skier00_00's Avatar
If you were to lock one axle which one would give you a better advantage? Or is this a poor idea?
Old 01-14-2013, 12:52 PM
  #25
Definitely the rear. Many lock only the rear.
Those that have front and rear, usually only the rear is needed. Front is only when you have something very difficult (or in ice/snow).
Another reason is that when the front is locked, it's harder to steer.
I currently only have the front, saving for the rear. When I tell people I only have the front, they are usually puzzled that I didn't do the rear first. I did the front because I did a front axle swap. Got rid of my D30 and got a Rubi D44.
Old 01-14-2013, 01:08 PM
  #26
JKingAround's Avatar
Originally Posted by Moraespedro
If someone has to convince you, you probably do not need a locker...
Times 2.......
Old 01-14-2013, 04:28 PM
  #27
triplethreat5188's Avatar
Just need to say that bld (brake lock diff) is the part of esp that is ACTIVE in 4 low... It is not as good as a locker, but it helps...
finally someone at least understand what I am talking about many people do not know about the bld but I'm not fighting for it but just saying its suppose to help but after thinking I might as well get the locker it will prob come in more handy than I think
Old 01-14-2013, 04:30 PM
  #28
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=409470"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=409471"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=409472"/>
not trying to be a jackass but I've done that with my open diffs before that's not the locker truly working you still have 3 tires on the ground
Old 01-14-2013, 04:37 PM
  #29
EzK
EzK's Avatar
I think tires and suspension are a bigger factor, if you haven't already put your money into those locations.
Old 01-14-2013, 05:18 PM
  #30
justinstoffregen's Avatar
Default locker hijinx
That's his whole point. When you have even one tire off the ground the power of 4wd is compromised. That's the whole point of a locker -- to prevent the 4WD power from taking the path of least resistance i.e., the tire that is OFF THE GROUND.
Quick Reply: Convince me to get a locker
