Convert Lift To Long Arm For Less?
I currently have a zone offroad 3" Lift installed and am about to buy all of the adjustable control arms aswell. I figured while i am at it, would it be possible to somehow convert my current lift kit to a long arm? Ive read about possibly buying long arm control arms? Does that seem possible? Any info or insight about what i should do is greatly appreciated. Im sure someones going to say just buy a full long arm but thats not happening... yet...
JK-Forum Founder
in order to go long arm, you will need to hack off your existing control arm mounts and install new relocated mounting brackets on the frame rails. with them in place, you can install the accompaning longer arms. that right there is the bulk of your cost. you can keep your coils, shocks, swaybar links, track bars and basic things like that if you have them but really, they're not gonna save you all that much and really, there's no need for long arms on just 3" of lift.
Former Member
You will need mounting brackets for long arms, you can't install the longer arms in the factory locations.
we have an upgrade kit for this
http://full-traction.com/detail.php?...TID=430&NOTES=
JK-Forum Founder
"much better"? no, not necessarily and it's a shame that so many people think that. longer arms will allow your axle to articulate more correctly but really, the point in running them is to help you keep your suspension geometry closer to stock when going big. the factory JK arms are plenty long and much longer than the old TJ and they're fine for running up to about 4" of lift. bigger than that, and you're most likely running 37's or bigger and i would definitely recommend them.
