Control Arms - Take your Pick
Old 11-02-2011, 08:42 AM
godeepwvu's Avatar
Default Control Arms - Take your Pick
First, I am not buying a full set of 8. Out of the question....too expensive.
Knowing that, what would give me the best 'bang for the buck' ? I've seen everything on here - front uppers only, Rusty's special fronts, lower fron + lower rear, front lower + rear upper. I'm slightly confused and need your help.
Old 11-02-2011, 08:46 AM
lopezv123's Avatar
Front lowers, rear uppers. Adjustable.
Old 11-02-2011, 08:53 AM
Ryan0260's Avatar
X2. If you are tight on money do the fronts first
Old 11-02-2011, 09:22 AM
1st timer's Avatar
Originally Posted by Jae Suite
Do all Adjustable uppers lowers can wait
Ok. so lopezv123 says front lowers, and you say all uppers, lowers can wait
Old 11-02-2011, 09:25 AM
D_engel's Avatar
Do front Lowers and rear uppers first, that is really all you need to correct caster or pinion angles. You need front uppers and rear lowers if you want to really dial everything in or center your axles.
Now for brands, I would recommend Rock Krawler. Essentially the same as teraflex, just cheaper. Ill be picking up a set soon.
Old 11-02-2011, 09:37 AM
scotty6336's Avatar
Makes me wonder why my RK kit came with the four lowers. I guess it's b/c they assume you're going to get uppers, which I am, but its still strange.
x4 on the front lower, rear upper combo btw.
Old 11-02-2011, 10:14 AM
tslewisz's Avatar
Since I have an RK kit on order, I've wondered the same thing. In my head, I've just settled on that they're "high clearance" and be happy with 'em. When I need to compensate for a different drive shaft I'll get their uppers, too, or just go 3-link.
Old 11-02-2011, 10:29 AM
jm102602's Avatar
TF sells a kit that comes with front lowers and rear uppers I would imagine that is a good combo.
Old 11-02-2011, 11:46 AM
scotty6336's Avatar
I like your thinking!!!
Old 11-02-2011, 11:47 AM
scotty6336's Avatar
Originally Posted by bubba_zenetti
2 inches or less lift front lowers and rear uppers
4 inches of lift, do it right or dont bother. get all 4 or you will be chasing your tail trying to correct geometry.
Oh cmon...two inches or less?? IMO no arms needed for less than 2" actual lift, but thats just me..I'm a minimalist.
Quick Reply: Control Arms - Take your Pick
