Control Arms Selection?
MANY people use TF control arms and are happy. I personally have front lowers and rear uppers. There are other good quality adjustables out there. Do a seach and you will be able to figure out what the collective group prefer. It won't take long for you to see what the top two or three choices are.
When you get ready to adjust the rear, most instructions have you adjust the pinion angle for double cardin style joints. If you have the factory drive shaft do not follow such instructions! With factory shafts split the angle between the front joint (on the rear drive shaft) and the rear joint. Double cardan style shafts require the pinion to be in line with the rear joint.
Have you looked at your rear coils springs? They may be very close to your track bar, if not hitting it. You might need some spring wedges. Watch the bow in the coils when you are adjusting your rear upper control arms.
