Control Arms Selection?
Old 03-17-2013, 10:14 AM
enash965's Avatar
Originally Posted by Jumpmaster
MANY people use TF control arms and are happy. I personally have front lowers and rear uppers. There are other good quality adjustables out there. Do a seach and you will be able to figure out what the collective group prefer. It won't take long for you to see what the top two or three choices are.
Do u need to do the rear lower if u do frot lower and rear upper also?
Old 03-17-2013, 10:42 AM
afpilot82's Avatar
No, you can do them all independently. If you're not going to do all 8 arms at once, start with front lowers and then rear uppers.
Old 03-17-2013, 10:53 AM
KSARG1's Avatar
Why front lowers and rear uppers? Why not lowers front and rear?
Old 03-17-2013, 11:03 AM
enash965's Avatar
I doing teraflex front lower and rear upper
Old 03-17-2013, 11:06 AM
RKracing's Avatar
Now you got it
Old 03-17-2013, 11:15 AM
enash965's Avatar
Originally Posted by RKracing
Now you got it
And I'll have someone adjust the caster so it's right cuz I'm not positive how to do it.
Old 03-17-2013, 11:30 AM
GoBig's Avatar
I run Teraflex front LCAs and UCAs, I'm very happy with them.
Old 03-17-2013, 12:17 PM
enash965's Avatar
Ok I'm gonna do front lower and rear upper TF. Did u install yourself
Old 03-17-2013, 02:40 PM
GoBig's Avatar
Both are front. I installed them with jks track bars (fr/r) and with an old man emu suspension lift. Did it all myself...very easy!
Old 03-17-2013, 03:37 PM
bbrown626's Avatar
check the write-ups or wayalife.com. It is fairly easy. TF also has good instructions.
When you get ready to adjust the rear, most instructions have you adjust the pinion angle for double cardin style joints. If you have the factory drive shaft do not follow such instructions! With factory shafts split the angle between the front joint (on the rear drive shaft) and the rear joint. Double cardan style shafts require the pinion to be in line with the rear joint.
Have you looked at your rear coils springs? They may be very close to your track bar, if not hitting it. You might need some spring wedges. Watch the bow in the coils when you are adjusting your rear upper control arms.
Quick Reply: Control Arms Selection?
