Control Arms Question
I have 4" of lift but never got adjustable control arms. My ride isn't great and alignment has been a pain in my a$$.
I'm looking at buying some control arms from "rusty's 4x4 parts" and need to know what sets I need for best adjusting my caster. As well as are there different lengths? I see some just adjustable control arms and I see some long arm suspension control arms? Which do I need?
Learning everyday - sorry. It's just easier to ask you guys.
To adjust caster you will want front upper adjustable control arms. You do not want long arms. Typically, the lower control arm sets wheel base or if you have a tire rubbing. The uppers adjust pinion angle/caster. Good Luck!
Thanks for the response! Is there a write up on installing control arms? I know about the thread by wayalife in doing the self alignment - but id like to see a install. Do you know?
If your complaint is related to the steering then you will want to install a set of lower adjustable control arms to adjust your caster. The upper control arms are used to adjust pinion angle but it will cont into play with the caster to a degree.
A long arm kit is not what you want. The long arm kit will require welding, cutting, and fabrication. Long arm kits are for the serious people that want the best performance off road.
Let us know if you want a quote on anything.
Front uppers or lowers can be used to adjust caster. Most of us get lowers. Long arms are a lot more work since you need to relocate the mounts on the frame (think cutting, grinding, welding...). You probably don't want to go there.
Do some research on the arms as to brand. I don't have anything bad to say about Rusty's, since I've never used them, but I may have read about issues with the joints. Not sure, though. My suspension is Rock Krawler. Just FYI.
