Control Arm Bolts
Old 06-02-2009, 07:45 AM
bigbluejk's Avatar
Originally Posted by Piginajeep
Just buy the bolt from the dealer, its only a couple bucks.
I sure the hell wouldnt drill out the hole.
x2. The thought crossed my mind for just a second, but I decided it is just to easy to get the right sized bolt instead.
Old 06-02-2009, 07:59 AM
chuck45's Avatar
Sometimes the 1/2 fits and sometimes it doesn't. It just depends on the tolerance of the original hole. It's no big deal to open it up a few thousandths; which is all you are doing.
Old 06-02-2009, 08:23 AM
edwin907's Avatar
Chuck's right, I probably could have gotten the bolt in if I "threaded i through the hole".
A couple of minutes with a small hand held circular file and it fit perfectly. Then hit the filed areas with the propane torch to heat it up, a little 1200 degree ceramic engine paint, and it's done..
Old 06-02-2009, 05:12 PM
popo343's Avatar
Yeah 55 dollars is way to much for three bolts and nuts.
Im fabbing up my own rear bumper with tire carrier so I need a few more bolts and just ordered from bolt depot. It was alot cheaper than the dealer. And as Piginajeep said I am not going to alter the bolt or the bolt hole.
Old 09-04-2009, 06:56 AM
james90755's Avatar
Sort of off the subject with regard to control arm bolts...
I am looking for torque spec for these when replacing the arms... I am guessing about 100lbs based on their tightness during removal, but I hate to guess...
New LCA's installed last night to fix DW... we shall see if it works.
Old 09-04-2009, 07:01 AM
mkjeep's Avatar
http://project-jk.com/jeep-jk-write-...orque-settings
Old 09-04-2009, 07:22 AM
james90755's Avatar
I knew it was in here somewhere... and I looked. (anyone seen my dunce cap? )
Where's the thread on how to search well?
Old 09-04-2009, 07:37 AM
mkjeep's Avatar
https://www.jk-forum.com/forums/forum-support-92/search-tips-28490/
Old 09-04-2009, 09:26 AM
james90755's Avatar
The only other question I have is why I keep adding mods...
that and where does one wheel in the Hammond area... my parental units just over the MS border from you...
Old 09-04-2009, 09:34 AM
mkjeep's Avatar
Cole's Creek- A huge capped over landfill area, and Paridise trail on the Tickfaw river.
http://www.youtube.com/watch?v=86napgo90hg
Kinda old vid, you may get the idea though
Quick Reply: Control Arm Bolts
