Confused about gears
Old 04-02-2012, 07:16 PM
  #41
snopro269's Avatar
Just run a 4.88 gear and I'm sure you'll be just happy!!! Or maybe not. Humm
Old 04-02-2012, 07:21 PM
  #42
troyboy's Avatar
Originally Posted by snopro269
.... Hostility man wow, just wheres the jeep fun loving attitude at? ....
comes from your post: "...But hey it's all calculated so it MUST be correct than real experience. "
Old 04-02-2012, 07:22 PM
  #43
snopro269's Avatar
Yupp your right absolutely. Ten four!! Wavy wavy
Old 04-02-2012, 07:23 PM
  #44
troyboy's Avatar
Roger that.
Old 04-03-2012, 03:07 PM
  #45
RSTRICK's Avatar
What is your rpm on the highway with overdrive off with the 5.13s and 35s? I imagine you don't need to do that but if you are pulling a boat you might.
I don't usually run with with overdrive off so really don't have a good answer for you but 3500 RPM at 65 mph. I pull a 5x8 utility trailer with lawn equip twice a week and leave OD on and I can maintain speed no problem. Real world speaking not a bunch of charts. Drove a 4:88 Jeep and after installing my 5:13's he swapped for the same set up.
Old 04-03-2012, 04:06 PM
  #46
troyboy's Avatar
Thanks. I was curious cuz I pull a 3500lb boat. Did the guy who went from 4.88s to 5.13s notice any difference at highway speed? It's only around 120 rpm difference.
I just recently switched from 34" heavy toyos to 33" light duratracs thinking it would help pullin the boat up this one steep hill. I couldn't tell a difference at all. Mind you the overall rpm difference doing that was only 66 rpm.
Old 04-03-2012, 09:22 PM
  #47
ToolManTimTaylor's Avatar
Originally Posted by ToolManTimTaylor
I DD my Jeep (All my gear is in my profile) and have 5:13's and 35's. I also wheel Race point and points south and am all over the cape in summer. Trust me the ONLY gear you need are 5:13's. Longhand I avg 18 Hwy and 15 around town to/from work backroads with big hills. With a 6-speed 4:88's on a '07-11 Jeep no doubt.
Now for strength ... meh I went 5:13's for strength reasons as 5:36's on a D44 front end is sketch with a teeny pinion. Now on a Dana 30 front the same holds true for 5:13's so some opt for 4:88's for the same reason. in terms of transmission options 6 speeds usually go 4:88's anyhow due to enherent gearing
Sorry I double checked today and O.D OFF I am @ 3250~ish @ 65 and 2250~ish O.D On @ 65
Quick Reply: Confused about gears
