Compressor Ideas
Compressor Ideas
Not sure if I posted this in the right place, but here goes:
What are my compressor options? I have been thinking of going one of 3 routes. The first is the kit from Dominion Offroad, the second is the ARB Twin Compressor CKMTA12, and third is an A/C conversion. I don't know much about the A/C compressor, but what I do know is that it needs some sort of oiling system, custom bracketry, and another belt (or simply a longer one). If anyone has any of these installed, hit me up with some pictures and any advice. I want to have the ability to run air tools and the ARB compressor says it will in the description, but I don't believe it. I know air tools are impractical on the trail, but it would be nice to have the option. Thanks in advance!!
JK-Forum Founder
for running air tools, you're best bet is to install a tank regardless of what option you go with. but, of the options you're looking at, a oba attached to your serpentine belt will give you the best results.
I can run air tools off my single ARB compressor; I'm sure the double would work just fine. I bought a cheap portable air tank from HF and it works to run an impact wrench I got. In fact, I had a discussion with the ARB engineers who recommended an alternate pressure cut off switch so I could boost the pressure. It's highly capable. My only complaint is that it overheats before it fills up all my tires after air down. It does 3.25 of them (37s) before the auto shutoff. I'm designing a cooling solution that I'm hoping will provide me enough time to finish the last one as well.
The Old Dominion set up is really nice but pricy... That's my first choice peroid and I may go that route one day if I decide on getting a tank...
Or you can pick up the Viair 2.5 gallon tank which the Old Dominion system runs for $69.99 and pair it up with on of ARB's compressors...
But in the end I like the out of the box nature of the Old Dominion set up, it's just plug and play!
http://www.quadratec.com/products/92043_1200.htm
That's a really awkward mounting point for a tank...and about the last place I'd ever want to put one. Considering air hose is cheap, and there's plenty of room by the frame rails, why would you add more things in the engine bay?
Belt driven OBA, IMO, is a better way to go, so the York setup would be my choice. Electrically driven systems put extra strain on the electrical system and create a lot of heat. I.e, you won't want to be using the compressor while on a hot day at night, with your rock & headlights on. Your alternator and battery would simply want to melt! And since you're running the truck anyway....
I have posted before with no response. I have seen on older trucks and Jeeps, the AC sytem converted to on board air. Has anyone done this on a JK? I would love to try it.
