Completely disable TPMS with Superchips?
Old 10-10-2010, 11:17 AM
ALinkToYourPast's Avatar
Default Completely disable TPMS with Superchips?
I was just wondering if there was a way to completely disable the tire pressure warning using Superchips. When I was playing around with it I could only set the tire pressure to 19PSI. I put 15" steel wheels on and didnt transfer the Tire Pressure sensors in the new wheels and would like to completely turn it off. Thanks in advance.
Old 10-10-2010, 08:13 PM
toymaster's Avatar
No, if there is I have not seen it. I would say it a liability thing for SC, it would be seen as defeating a safety device. I have mine set to the lowest also.
***Edit, I stand corrected.
Old 10-10-2010, 08:35 PM
whpony96's Avatar
Yes you can but you have to upload the feature into the SC Flashpaq VIA the Superchips Update software.
Old 10-10-2010, 09:01 PM
JKMudder's Avatar
Indeed there is. It actually took me a few attempts to get it to download/update correctly and load into the unit. But mine are now disabled.
Old 10-11-2010, 03:55 AM
JPop's Avatar
Yes, you need to have a digital signature of sorts to be able to download and use the TPMS delete option. It was all in the hands of the attorneys and took a little bit of time to get done. Definitely there and you just need to state that you understand what deleting the TPMS option does, and also what is appropriate use of it along with where driving your vehicle with it deleted is appropriate.
Old 10-11-2010, 07:06 AM
JerryJeff's Avatar
Superchips basically got around the liability issue by labeling the software upgrade "off-road only".
Thank You Superchips!!
Old 10-11-2010, 07:17 AM
thanks guys. I did update the software when I first got it, but I will go back and do it again. Goodbye idiot light!
Old 10-11-2010, 10:19 AM
stig's Avatar
So you just go to the SC easy update thing? Do you actually have to search for it or does it load to the flashpaq automatically?
Old 10-11-2010, 10:21 AM
JKMudder's Avatar
You have to go to the little upgrades section. Its a free "upgrade". Click on it, check out and then it should install it.
Old 10-11-2010, 10:27 AM
stig's Avatar
Hmmm. I see the "upgrade" part at the botom. I can't click it. it still says "updating programmer".
Quick Reply: Completely disable TPMS with Superchips?
