Compass
Most common cause is the compass has been removed for some reason, then installed 180° from the correct position.
A common cause for it to be off less than 180° is having something metallic or magnetic on top of the center panel.
You could try a Manual Calibration and see if that does anything. The procedure is in the owners manual. (can be downloaded from the jeep website if you don't have one.)
