Companies Pushing Dual Rate Coils
Old 03-10-2016, 07:34 PM
sa29560's Avatar
Originally Posted by jedg
What is your actual (measured) lift? If you're headed toward 37s, are you thinking about going with 3.5" instead? I just switched from 2.5" RK (progressive front / linear rear) to RK 3.5" triple rate, all else remained the same. There is a significant difference in the unsprung height between the two (around 6 inches). That said, I got 3 1/8" measured lift. (my JKU is heavy). I no longer have coils that unseat and the ride feels a bit softer.
I got just over 3 and it held pretty strong for the time I've had them. Was definitely considering a 3.5 coil set as I already have all the necessary parts to lift even higher. And would have no problem clearing a 37. Could fit it right now. I would lose some up travel I'm sure.
My jk is light up top, I'm pretty sure I'll get more than "advertised" with most reputable brands.
Old 03-10-2016, 07:50 PM
jedg's Avatar
So really, perhaps your only reason(s) to get new coils is the current ones look bad? Or they unseat on droop.
If they just look bad, I used VHT Epoxy Paint on mine and that held up great.
If they are unseating, then going to any of the multiple rate springs would be worth considering. Marcus at RiverCityOffroad is who I worked with. He was spot on with his recommendation for me. The coil/shock combination I have now works great.
Old 03-10-2016, 10:22 PM
sa29560's Avatar
So really, perhaps your only reason(s) to get new coils is the current ones look bad? Or they unseat on droop. If they just look bad, I used VHT Epoxy Paint on mine and that held up great. If they are unseating, then going to any of the multiple rate springs would be worth considering. Marcus at RiverCityOffroad is who I worked with. He was spot on with his recommendation for me. The coil/shock combination I have now works great.
Mostly yes. I have had some instances where the coils were nearly dropping out on the front, have retainers in the rear.
Not only do they just look old I am just looking to upgrade for better ride quality and of course flexibility and control in the rocks. My shocks are pretty new but doesn't mean I wouldn't purchase some to compliment a new spring. I'll have to call around and see what my options are.
Thanks for all the help.
Old 03-11-2016, 02:59 AM
kjeeper10's Avatar
So what, specifically, is misinformation?
X2 (10 char)
Old 03-11-2016, 05:00 AM
N2MWL's Avatar
still waiting for it..
*crickets*
Old 03-11-2016, 05:09 AM
busa250's Avatar
Originally Posted by N2MWL
still waiting for it.. *crickets*
lmao!!
Old 03-11-2016, 09:28 AM
DJ1
Former Member
DJ1's Avatar
Old 03-11-2016, 12:57 PM
LoneWolf's Avatar
Originally Posted by DJ1
Only thing is that I don't think AEV sells the triple-rated coils by themselves.
That's true, and so frustrating. I really like the AEV 2.5-inch lift, but I hesitate buying a kit from a company that won't sell me the individual components if/when the time comes that I need them. it just makes it that much harder to justify the kit's $1,105 price tag (with C/A brackets). Instead, I'm eyeing the Metalcloak Expedition Sport kit. It's a little more costly, but includes more parts to justify that price, too.
Old 03-11-2016, 07:25 PM
jadmt's Avatar
if you have the kit and break something you can get replacement parts for aev. I live next to their r and d shop and have talked to them many times.
Old 03-11-2016, 07:30 PM
jadmt's Avatar
weird I just went from RK triple rate 2.5" rear coils to RK 3.5" triple rates and there was exactly 1" difference in free height and exactly 1" difference in actual lift. I like the triple rates that's for sure.
Quick Reply: Companies Pushing Dual Rate Coils
