Combination Setup question
So I have been searching the forum for about 2 weeks now and i have found either unclear or conflicting info. SO to keep things easy and clear, i'd appreciate some advice.
I have a stock X 2dr soft top manual. I am looking at the TF 2.5" coil and I am told I should get abotu 3.5" total out of the lift
I picked up some 17x9 steelies with 4.5" back space. Will I need wheel spacers so I won't have rubbing?
I was planning on 33"s but I see people saying go with 35"s. If I got with 35"s, will I have to regear or is that not an issue on a manual 6spd?
The whole setup I am looking at right now is:
#1251000 2.5" coils/shock
#1513001 steering stabilizer
#1753418 front Forge adj. Trackbar
#1653700 front lower adj. control arms
#1055000 wheel spacers (1 pair 2 are needed)
Anything else is should consider?
Thanks guys!
Thanks guys!
The different sections in this link should easily answer most of your questions:
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
