which coils
#21
Was thinking about king 2.0 shocks but decided to save the money for coils. So Imma just run Fox's. I'm just curious one either the evo coils or metal cloaks. I'm gonna be running metal cloak control arms.
#22
Go with the MetalCloak coils if you are running longer shocks. I run shocks for 4-6" of lift and the springs won't drop out at full extension. I recently installed a buddies RK 3.5 with the same shocks. On the lift the coils would just fall out at full extension. I had similar issues when I was running EVO coils, but I was also running their Rockstar skids which allow the axle to drop a bit further.
#27
#28
#29
I get that, but he said he would be running fox shocks. On the RK setup I installed(3.5 x factor plus) the rear springs would easily fall out on the lift when fully extended without any sort of coil retainers. The metal cloak springs wouldn't do that on my setup with the same length/brand shocks)
#30
Ive seen it also, but he could make rk synergy currie or metal cloak work if he wants... Honestly in 12" ish or more travel you should be looking at coilovers.
