Coilovers and daily driving.
Generally speaking, it's hard to stuff a 12" shock into factory brackets and not limit your up travel substantially. So you may not gain more total travel with a coilover, but you can custom tailor your up travel and down travel ratios a little better, keep your rig lower, more stable, etc. however if you're going to go thru the effort of CO's, go 14's up front.
BB, yep. Those are the ones I'm running. In conjunction with airbumps & teraflex arms (8).
Attachment 455869
Attachment 455869
Is there a significant benefit over my coils and shocks when at higher speeds on rough trails?
As opposed to? Coilovers? I was running fox 2.0 remote resis and aev coils previously. Also ran the foxs with teraflex coils. No comparision between the 2. Coilovers are the way to go on road and off. Especially high speed stuff. If high speed off-road is also in the plan, airbumps frt and rr are the only way to go.
Would you say that the air bump stops (e.g. Fox) have an advantage over the Teraflex "cell micro-cellular polyurethane... maintenance free" bump stops?
FOX -- http://www.offroadwarehouse.com/prod...roductID/56209
TERAFLEX -- | TeraFlex Suspensions
Depends on you and driving. If you're not one that likes to keep up on checking pressures once in awhile, or really take continuous fast/hard hits then the other options should be fine. I also enjoy desert runs, in addition to the slow rock stuff. Airbumps were the way to go for me.
I'm not sure I understand some of what you say:
"If you're not one that likes to keep up on checking pressures once in awhile, or really take continuous fast/hard hits then the other options should be fine."
I understand this as - 'For both service-free AND frequent hard hits, the Teraflex is better' - right ?I, too, sprint offroad. I'd prefer maintenance-free, but not if the Teraflex doesn't absorb hits as well as the fox.
Also, how often should the pressure in the Fox be checked? Just after rough rides, or periodically?
Thinking of it, the Teraflex is actually based on air compression as well -- as the compressed material is made of closed cells that contain air.
If you read off road magazine the used some poly filled bumps and after couple months of use some of the cellular disc inside where flattened. They ended up taken off for air bumps. I've never used either so I'm just quoting what i read
It would be interesting to see what Teraflex have to say about this.
