Coilover vs standard sping lift
A related question : Specifically for going fast over rocky uneven terrain, why is a coilover better ?
Both set-ups (coilover vs coils+shocks) have the same basic materials - a spring with a shock absorber - so I've wondered is the benefit that a coilover strut reacts quicker to high speed terrain changes than a regular coil with shock absorber ?
Cheers
Cheers
Sorry man, but sometimes the truth hurts. I don't think WOL was trying to shoot down your kit, it's just not comparable to what both he and I run. Yes, the EVO double throw down is über expensive for the average joe, but if you are wanting the best in articulation and high speed performance there is no other system out there that can touch the EVO DTD. Soon there will be the EVO bolt coilover kit that will make all other bolt on kits inferior. I can say this because, One- I have run other coilover setups on other rigs throughout the years. They are problematic, not well designed from the ground up, but more an after thought. They can't touch the EVO DTD. Two- I have seen firsthand what the new EVO bolt on kit can do performance wise, and it blows conventional coil spring systems away. It's going to set the bar very high for competitors kits. Simply running front coilovers is going to, at best, only give better performance up front. You need to address the rear too, or you haven't really done anything accept put really expensive, tunable shocks up front.
Bottom line, if you really wheel in difficult terrain (compare your photos with Wayoflife's, huge difference) than coilovers are probably needed. Not trying to beat you up here either Other than price, there is no "con" in my book
Below, more pics of EVO DTD articulation, my rig and Mel Wade's EVO1. Only possible with a great designed system for the front and rear
Why is there a need to bash another companies products? Yes EVO may be the best but does that require the bashing of another manufactures products. Why isn't it possible to put the statistics from the 2 kits side by side and let someone choose? Being an active member of a forum becomes less appealing when the moderators and operators of the forum are bashing everything they don't like.
