Coil spacers for more lift vs larger coils
Am thinking of going a little bit bigger on my short arm setup and was curious of what people experienced when they added a 1 inch spacer to their current 3 lift. Did it seem more firm vs going to a longer spring ?!
Itll feel the same, you just have to do some castor correction and possibly throw on some new drive shafts with that much lift. I plan on adding another 1 inch coil spacer when money allows for everything to do it properly (i.e shafts, adjustable control arms, etc.)
I currently have an 8 arm TF setup with castor that I added in the front. Just curious about the ride.
I have done various lifts in the past on different brands and everyone that I ever put spring spacers rode "less appealing " than a progressive spring without spacers
Originally Posted by TheDirtman
At 4" you might encounter steering issues but the coils will perform the same as before.
Also my jeep weighs in at 5300 lbs without gear and I am planning throwing a river raider full skid as well
I'm thinking the current 3 inch coil plus an added spacer will help me out
