coil spacers
Everybody makes a mistake, Apple just happened to make all of them at once and labeled it "iPhone"
This is what happens when your stuck in the barracks with nothing to do. But, one more crack about my iPhone and I'll do a special relocate of your breathers when I come over for our custom snorkel project!
Who had service when we were down at corolla? Oh yeah, my droid did. Who had maps when we were down there? Droid again! Who had a super sweet paper weight? iPhone for sure.
Coil spacers will work well for the OP.
The shocks should not limit travel. If you're using the shocks as travel limiters then the shocks won't last forever. There is a reason that professionals use travel limiting straps.
On stock jeeps the downtravel is limited by the sway bar links. If you start picking up the body of the jeep the swy bar links extend all the way before the shock does. No, I don't run straps because my jeep is a daily driver. If I hit a 6" pothole then I deserve a bent rim.
My warning was to simply let people know that the stock shocks have a limited travel range and running them with a coil spacer lift without the shock extenders isn't the best idea. There has to be a reason the lift kits include shock extenders or longer shocks.
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
1 Post
I was thinking about doing the same as the OP to my Sahara.
Dont want anything radical. Just something for a little edge.
Also thinking about Spidertrac wheel spacers
as I dont want the expense of getting new wheels/tires..
The coil lift will look good. I put rubi coils and shocks on with TF 2.5" BB and live it... Guess I kind of made my own coil lift...
