Coil spacer take away articulation?
It doesn't necessarily show here, but it has a very slight rake (I have to put a level on the frame to check it). I think a slight rake is desirable as you have some room to add equipment and not get a reverse rake:
Yeah, install your equipment and then see...
GreenJK07 - 35s.
GreenJK07 - 35s.
I'm glad I saw this thread. I have been wondering what size, if any, I will need to add after bumper and winch go on in a few weeks. I have the tf 2.5 coil lift also. Sounds like a 1/2" spacer will do the trick.
I've had my tires hit my pinch seam, so all the "buzz" that the tire drops down and back is a little confusing. When I'm stuffed it dug in, I trimmed my seams, JB welded them then painted them.
Flat flares are next...
Stuffed pic after seam trim:
