coil spacer kits and brake lines
I just finished putting in a AEV 2" coil spring spacer kit on my 2015 JK Unlimited. I did not use the supplied brackets to drop the position of the front factory brake bracket. The hard lines have literally no play in them to do so. Do I need to use these brackets if I am not going to be doing any rock climbing? Should I install some longer braided lines instead? Does anybody know of a cool way or bracket to support the front brake lines other than zip tying them to the lower shock tube? Thanks
