Code problem
Code problem
Just was driving an had the traction control come on an stay on which I'm guessing is a code... I tried the key trick( turn 3 times an display the code) but all it show is a bunch of dashes the says done an beeps twice... I have the pro cal too didnt know if this would help at all? Any suggestion or help would be much appreciated....
Thanks guys
Thanks guys
JK-Forum Founder
more than likely, your steering wheel is off center just a bit. if you have a procal, you can use it to recenter your steering wheel and, after the computer is cleared out, it will keep it from coming on again.
